BMP007
WLAN allways say "No Internet"
Tue Jun 13, 2017 8:57 am
Yesterday i become my new BV6000.
I try to connect with 4 WLANs everytime i get the Message "Connectet, no Internet"
With the same options on my Samsung S6 it works.
Have anyone a idea ?
BMP007
Re: WLAN allways say "No Internet"
Tue Jun 13, 2017 12:34 pm
I cant connect to any WLAN if i use a Static IP with a WLAN that is Encryptet (WEB, WPA2). It always show me "Connect, but no Internet" !
If i remove the Crypt (WEB) i can connect with Static IP.
Without a Static IP i also can connect.
Wed Jun 14, 2017 8:31 am
Thanks for your feedback.
Do you have the latest Firmware 20170517?
Has anyone else the same problem with WEP2-encrypted Wifi connection and static IP?
Wed Jun 21, 2017 2:16 am
Should try resetting the router or changing to a dynamic ip permanently.
Tomator
Thu Jun 22, 2017 11:27 am
The router may use the Samsung's MAC address to identify a phone to to apply static IP. BV has different MAC. Router configuration may need update.
BV6000 P2 BV9500Pro
