poeli
Re: BV6000 Mic Problem
Sat Jul 01, 2017 12:45 pm
I tried the settings and doesn't work! very frustrating to have this on a new phone! it worked before and now it doesn't anymore
phil_s
Wed Aug 23, 2017 5:59 pm
after months and hundreds of other complaints (also for P2 lite) you still don´t have any solution for the problem???
such a huge community giving you feedback and hints and you just ignore it?
It was the first and last Blackview for me!
Tomator
Mon Sep 04, 2017 11:35 am
I have two microhone problems at once,
1. People complain they hear me like I was talking from a distance when speak with the phone by my ear.
2. I get loud white noise on the recording, either video or audio, using sound recorder which volumeter shows half of the scale in silent place. I have to blow into the microphone or knock the phone near the microphone so the volumeter is pushed to the limit and then fall down to zero which makes sound recording possible.
I tried using engineering menu but I was able only to rise or lower the microphone sensitivity but still the only the noise was present until I knock or blow - but I had to do it harder. It's like the initial sensitivity was too high so the internal noise was recorded - but why did it prevent the phone from hearing anything else? On a phone call the microphone works albeit not perfectly. It's hard to adjust it sins I cannot call to myself...
My BV6000 is running on 20170708
BV6000 P2 BV9500Pro
Fri Sep 08, 2017 4:18 pm
If you have issues with the microphone only during calls try to disable "OK google" feature.
Tomator
Tue Sep 19, 2017 7:22 pm
Hi Admin,
I have "OK Google" disabled. This must be something else.
BV6000 P2 BV9500Pro
papapedrox
Tue Sep 19, 2017 8:18 pm
Great solution th engineering mode! I solve the issue of low microphone level setting to 240 the UL gain.
Thanks admin!!!!
:D :D :D
Tue Sep 26, 2017 6:56 pm
Thanks admin!!!!
:D :D :D
Thank you for the feedback!
