SnuffThePunkz
7.0 update
Sat Feb 25, 2017 4:42 am
Is it worth it guys?
I'm in Canada and not getting an OTA update, still on 20161011. Wondering if I should bother upgrading it manually or just leave it alone?
For the record, everything is fine. No issues other than the shitty speaker which I have two coming. (Found out about the warranty replacement hours after ordering a SECOND replacement.)
kup0
Re: 7.0 update
Sat Feb 25, 2017 5:09 am
If you have phone that works don't update. 7.0 have so many bugs that it's better to wait and hope Blackview fix it.
SnuffThePunkz
Re: 7.0 update
Sat Feb 25, 2017 5:50 am
Sounds like 6.0 update for the bv5000 all over again then. Thanks.
Curious how the bv7000 pro is...
mobosenshi
Re: 7.0 update
Sat Feb 25, 2017 8:55 am
I had zero problems with my 7.0 update.
custal
Re: 7.0 update
Sat Feb 25, 2017 10:08 am
Same here, apart from a slight increase in power consumption, everything is working smoothly.
kup0
Re: 7.0 update
Sat Feb 25, 2017 1:36 pm
How did you install it? OTA and factory reset? Is bluetooth working? How about Sygic navigation, does it work?
BlackCat
Re: 7.0 update
Sat Feb 25, 2017 4:14 pm
For getting the Update on 7.0 you need first the 025 Version of Android 6
BV9900 PRO
BV6000
BlackCat
Re: 7.0 update
Sat Feb 25, 2017 4:18 pm
I did it with OTA
No Factory reset
is working well, my alarms are deleted
to times Problems with play store after updates no problems
sometimes the battery-level is sinking very quickliy
but still enough power for two days with all time Wifi or 4G on
BV9900 PRO
BV6000
custal
Re: 7.0 update
Sat Feb 25, 2017 4:40 pm
OTA, everything is working. Though I'm not using Sygic but Google Maps for navigation.
ThomasSc
Re: 7.0 update
Sat Feb 25, 2017 5:23 pm
Sygic doesn't work with this 7.0.
If you happy with 6.0, stay on it, like me.
There are no benefits on 7.0.
I'm back on 6.0.
Users browsing this forum: No registered users and 14 guests
