Fri Dec 23, 2016 10:53 pm
So I tried installing the update through OTA. It downloaded, unpacked, but then got stuck in the "Reboot..." message; it didn't reboot at all. Waited like 30 minutes. I tried it several times.
Next was the local update, which did the same as the OTA update: it doesn't reboot even after waiting like 20 to 30 minutes.
I tried flashing. "SP FLASH ERROR: 8417", the scatter file is apparently invalid or I'm plain stupid to install a driver.
My phone is still running on V01_20161011. I'm giving up this update entirely because I tried doing the same thing over for weeks. If it doesn't want to work, then it can't be helped.
