E7 Flash Manual On Windows 10 64-bit only
Wed Nov 30, 2016 9:34 am
Anyone in need of a flash Manual for E7, can visit the link below for PDF tutorial files.
link: https://mega.nz/#!bll2gbKQ!apVEHfnOOreP ... ugsqDHiQYo
Some flash tools you may need for this manual:
PC with installed Windows 10 64-bit
USB VCOM driver:
https://drive.google.com/file/d/0B6chOQ ... 25GMjRGTlk
Firmware itself. It is a folder with a set of files (MT65xx_Android_scatter.txt, system.img, recovery.img, boot.img …..)
https://drive.google.com/open?id=0B6chO ... FctUTgwUlk
Software for flashing - SP Flash Tool
https://drive.google.com/open?id=0B6chO ... DlaREYwRW8
devillg
Re: E7 Flash Manual On Windows 10 64-bit only
Thu Feb 09, 2017 8:27 pm
Good night, I've tried this procedure for 1000 times, in my E7 and it's nothing. Have another process, can you help me.
thank you
:ugeek: :ugeek: :ugeek: :ugeek: :ugeek: :ugeek: :ugeek: :ugeek: :ugeek: :ugeek:
jameschong
Fri Mar 03, 2017 8:41 pm
Hello, how are you? Question: and the present material but for those who have windows 7 ??? Because I had the win 10 installed and I was very bad ... is there a possibility that I make a manual for this operating system ??? thank you very much
Jameschong
Caracas Venezuela
(My apologies for my English, but it's from the google translator)
