Kharyn
How to do screenshot
Sun Mar 06, 2016 7:51 am
I just want to know how to do screenshot on this phone? I tried pressing the power button and the volume key but it doesnt work. I even tried downloading an app to do screenshot but when it does, it says "system UI has stopped".
Re: How to do screenshot
Thu Mar 10, 2016 5:58 am
hi,
you should press the power and volume-at the same time , and the press time should not be too short.
Best regards,
Admin
Kharyn
Fri Mar 11, 2016 1:01 am
Already did it a hundred times but didnt work even once.
Sat Mar 12, 2016 3:22 am
hi,
suggest to do a factory reset,when the smartphone work properly , then do a screenshot
Best regards,
Admin
jackbox
Wed Mar 16, 2016 9:54 am
Mine works. Are you sure you are holding power button and volume down button at same time for at least three seconds?
strumf
My apps are not starting
Sun Mar 26, 2017 5:40 pm
Hi, I'm so sorry because my theme is different, but I need help. My phone, Blackview a8 can't turn on. Firstly, the home page was black and I can't saw my apps. Then, I remove my battery and put it back. The counting of apps started, and after that there is ' starting apps'. My apps can't start, I was waiting for 6 hours.. Can someone help me? Please. :(
Annaleedap
Thu May 04, 2017 8:35 am
You click f2 for dah screen shot. if you want to check out your screen shot, type appdata and click on .minecraft then ya click on deh screenshot folda and ya find dah picture As simple as that :3
<a href=http://ppv.alipromo.com/ru/intimate_ny.php?hash=opc0grtfb2u74luc94nd11ocyzvbp4rh&sub=IntimItems&currency=USD>женские интимные игрушки</a>
