E7 remove X icon missing ?
e7user
Postby e7user » Mon Nov 14, 2016 9:42 pm
It is impossible to remove an icon from home page because " Remove X " choice doesn't appear when you touch & hold an icon on the home page. Only "information" and "uninstall icon" appear at the bottom of the home page ?
How to get the "Remove X" choice at the bottom left of the home page ?
Re: E7 remove X icon missing ?
Postby blackview_admin » Tue Nov 15, 2016 6:49 am
The icon for preloaded apps in the phone can not be removed.
e7user
Postby e7user » Tue Nov 15, 2016 12:01 pm
Hi
Thanks for your reply.
Ok for preloaded applications but the problem is the same for added applications loaded from the playstore ?
regards
Postby blackview_admin » Thu Nov 17, 2016 8:35 am
e7user wrote:Hi
regards
reboot your phone,or do a factory reset to see if problem can be solved.
e7user
Postby e7user » Sun Nov 27, 2016 9:42 pm
A factory reset doesn't solve the bug
Return to “Service and tech”
