jackbox
What has changed in BV2000 firmware B2 model on 26th May
Sat Oct 22, 2016 3:13 am
Can someone please explain what was changed in this May 26, 2016 ROM? Is it worth flashing? Blackview just dropped a new ROM with no explanation and not OTA. Can flash with SP program only. I'd like to know if the changes are worth flashing. Thanks.
djbobo
Re: What has changed in BV2000 firmware B2 model on 26th May
Sun Dec 25, 2016 11:51 am
I know this post is kinda old but I'll reply it anyway so it might help anyone interested.
I did flash this newer rom. However I cant see much difference. Maybe it runs a little smoother but you would probably need to make some benchmarking with both to tell exacly what the difference it makes.
