  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
kup0
Rooted problem
Wed Sep 07, 2016 6:07 am
Is there going to be fix for this issue? There are few older posts for this same problem so I'm not alone with it. I checked with CPU-Z and it says my phone is not rooted but some apps says it is. My banks app don't work and looks like google pay (?) is all so not working. Please fix this issue!
Re: Rooted problem
Thu Sep 08, 2016 6:36 am
Or screenshot the UI for us as a judgement, or check if you can delete some preloaded apps or not.
In fact, all products from us are not rooted, unless the users themselves get the root.
kup0
Re: Rooted problem
Thu Sep 08, 2016 7:46 am
blackview_admin wrote:
Do you have any idea what app might cause this? This phone is not rooted but something makes it look like it's rooted. Is it app related or something strange in ROM or kernel that I don't know.
Derk
Re: Rooted problem
Thu Sep 08, 2016 8:07 am
@Blackview_Admin:
you possibly solve this issue in releasing ROMs with correct build properties.
As mentioned by some users including myself the ROMs are released as "test-keys" which is used for possibly unstable Beta and not the correct "release-keys" for stable version released to all users.
It's just a minimal correction your developers should be used to...
I think they just build the test version and make Beta test, may be some corrections and then forward this version for public release. This would also explain that the ROMs have a date prior than you publish them, usually the date difference should be 0 to 1 days when publishing.
Re: Rooted problem
Fri Sep 09, 2016 6:01 am
Derk wrote:
@Blackview_Admin:
so what is the date of your ROM? please know all roms has got a inner testing from the software department. Only when it works well , we will
do a public releasing. Then users will receive the new ROM. the test version won't be sent to users.
Re: Rooted problem
Fri Sep 09, 2016 6:06 am
do you have verified if the device is rooted? If it is not rooted, you can try a factory reset to see if the problem still exist.
Derk
Re: Rooted problem
Fri Sep 09, 2016 5:21 pm
Derk wrote:
@Blackview_Admin:
I use 20160822 - but that ROM was announced by you 20160901 - so the name suggests the ROM was compiled 10 days before release.
And if you have a look at the file default.prop in root directory you find the build properties at the very end.
The exact build date is: ro.bootimage.build.date=2016年 08月 22日 星期一 16:08:05 CST
And the build fingerprint is: ro.bootimage.build.fingerprint=alps/s12v55_jk_3m/s12v55_jk_3m:6.0/MRA58K/1471853073:user/test-keys
As you can see the build properties are user/test-keys which is ok for Beta-testing but not for release as there are some apps which might take the device as rooted as it is running a non productive ROM - all "test-keys" ROM are considered not for productive use but for testing only!
So please ask your developers to compile the ROM for release again after testing with build properties of "release-keys".
The correct procedure of signing they can find at https://source.android.com/devices/tech/ota/sign_builds.html
Regards,
Derk, former quality manager at Europes largest software company
kup0
Re: Rooted problem
Fri Sep 09, 2016 8:41 pm
Derk wrote:
@Blackview_Admin:
Regards,
Thank you Derk! Maybe they understand now that factory reset is not going to fix it.
Sebastl
Re: Rooted problem
Fri Sep 09, 2016 8:52 pm
On Needrom a Rom from 0818 appeared which is correctly signed and also has the ro.secure and ro.debuggable correctly set.
But it seems to be for a s12v55_jk_3m_gms_rz device whereas all the Roms posted here are for s12v55_jk_3m
Can you enlighten us Admin ?
styxxx
Re: Rooted problem
Wed Sep 14, 2016 9:56 am
Pokemon Go doesn't start anymore because of this. It's pretty amateurish by Niantic to detect the phone as rooted but I guess it wouldn't happen, if the firmware had the correct flags set.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
