macmax
disable vibrating in outgoing call
Wed Feb 10, 2016 6:38 pm
how i can disable vibrating when an outgoing call is made? i disable all the vibrating option but it do again...how i can solve? is a bug? and please implements also double tap to wake.
Re: disable vibrating in outgoing call
Thu Feb 18, 2016 8:11 am
hi,
you have try to find solution on setting menu ? if yes, you can try a recovery to factory setting .
Best regards,
Admin
