jakk81
POOR gps = disappointing
Fri Aug 12, 2016 7:59 am
i have the r7 and most seems good but gps is very bad it takes a long time to lock on to satalites and when it does the location is jumpy is there a fix for this im based in the UK,
i have the latest software already this is a problem and we nees a fix asap.
thanks Anthony
Re: POOR gps = disappointing
Sat Aug 13, 2016 6:56 am
thanks Anthony
we will try our best to improve the performance soon.
Best regards,
Admin
canaac
Thu Sep 08, 2016 9:37 pm
Hi, you know something of improvement for GPS?
I'm from Spain and the GPS works really bad.
A greeting.
canaac
Fri Sep 09, 2016 12:52 pm
I think I found the problem, but not how to fix it.
I'm root and I installed MTK Engineer Mode. When I go to "Location, YGPS, Information" indicates that "GPS: enabled / Status: Unavailable / TTFF: Counting".
How could fix this ?, because the GPS does not work, it only works with the data network.
Thank you.
A greeting.
lalo4470
Sat Feb 25, 2017 12:50 pm
I am looking to buy a BV6000, but I will only buy if the problem with the GPS has been fixed.
Can anyone tell me if the GPS is already working?
