andreaHuttner
Phone only starts chargin after restarting with the charging cable attached
Wed Jun 12, 2019 6:24 am
I have this problem, that the phone only starts chargin after restarting with the charging cable attached. The charging cable is the original cable from Blackview. The phone is updated to the newest version.
Can you help?
Re: Phone only starts chargin after restarting with the charging cable attached
Wed Jun 12, 2019 11:00 am
Hi there!
To rule out if this is a software or an hardware issue you'll have to perform a factory reset from the recovery menu, as showed here:
http://bbs.blackview.hk/viewtopic.php?f=192&t=334922
Keep me updated.
