RapFan
Cannot login to google account
Fri Feb 01, 2019 8:06 pm
Hi there,
i got this device brand new, but had this issue out the box, i've already did a factory reset (by settings).
How can i solve this problem?
Re: Cannot login to google account
Sat Feb 02, 2019 3:12 am
Try to disable and re-enable such app again, and clean its memory.
RapFan
Sat Feb 02, 2019 11:30 am
Nothing
RapFan
Sun Feb 03, 2019 10:52 am
I've tried by disabling all admin apps in settings menu, then i went to disable google play services, cleared cache and all date, then i've reenabled again, but got no result.
Maybe do i need to reflash the rom? Or update google play services manually by apk? But which version?
RapFan
Sun Feb 03, 2019 12:52 pm
Ok solved by flashing "backup_20180511" firmware posted by serg2327 in this thread.
Thu Feb 07, 2019 9:40 pm
Great! Thanks for your feedback!
