Blackmamba
bv5800 pro flash problem
Fri Jan 04, 2019 6:35 am
Hello.
My bv5800pro stuck at bootloop.
first i tried to factory reset the phone but without luck.
Then i tried to flash it but i cant flash rom. There is an error STATUS DA HASH MISMATCH.
I also try with SPmultiportflash.
please help.
Re: bv5800 pro flash problem
Fri Jan 04, 2019 10:05 pm
did you try to factory reset it by settings menu or by booting it into recovery mode?
Blackmamba
Tue Feb 05, 2019 12:18 pm
Yes i already tried that but no luck.
The device stuck on bootloop...
i tried with recovery menu but there is an error data corupt
Thu Feb 07, 2019 9:13 pm
Unfortunately the only solution will be contacting your seller to have it replaced under warranty. Bootloop usually points to an hardware failure.
