Corson336
Very quiet speaker
Wed Dec 26, 2018 6:00 pm
My p10000 seems to have only one speaker working at the bottom or it is at half volume
When I used to turn the phone on it was very loud now I can hardly hear it
Is this a software thing or hardware?
Can it be fixed easily
Re: Very quiet speaker
Wed Dec 26, 2018 9:19 pm
It looks like an hardware fault, but to rule it out please perform a factory reset,  try again and report back.
Corson336
Thu Dec 27, 2018 6:56 pm
No change with factory reset
Fri Dec 28, 2018 12:43 am
It looks like an hardware fault. If you phone is still under warranty, please contact your seller to have it replaced or repaired without additional costs.
If your warranty ended, you can try to replace the speaker by yourself. Here you'll find the spare part:
https://www.aliexpress.com/item/New-Lou ... st=ae803_3
https://www.aliexpress.com/item/ocolor- ... st=ae803_3
https://www.aliexpress.com/item/For-BLA ... st=ae803_3
https://www.aliexpress.com/item/Origina ... st=ae803_3
