  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
slxx
Root procedure ?
Tue Nov 20, 2018 4:46 pm
is there a chance we can get a clean root procedure for the bv6800 pro (i like my firewall) ?
Seems that's the only thing missing to this phone :)
Thank you.
regards,
S.
Re: Root procedure ?
Wed Nov 21, 2018 1:58 am
Hi there, root can't be officially supported for obivous reasons. I can't help you with that, but i'll keep this thread open so that users can help you and talk about it ;)
slxx
Wed Nov 21, 2018 10:55 am
Thank you for your answer :)
Just to know, would it be thinkable to include in the ROM some build-in firewall (like afwall+) (within the system, with the good right, there's no need to get root), or is it forbidden by android license / impossible to make ?
That would be a huge commercial advantage for your phones.
Btw, i just got my 6800 pro, and for now i'm really happy about it !
sams
Wed Nov 21, 2018 10:35 pm
Magisk is the best option imho. You just need to flash a boot image modified by Magisk Manager. No modification of the recovery or system partitions : easy OTA updates.
Short version :
  • Extract Boot Image with SP Flash Tool (version 5.1828 works fine)
  • Copy boot image to your BV6800 Pro.
  • In Magisk Manager, press Install > Install > Patch Boot Image File, and select your stock boot image file
  • Magisk Manager will now patch your boot image, and store it in [Internal Storage]/Download/patched_boot.img
  • Copy the patched boot image to your PC.
  • Flash the patched boot image with SP Flash Tool to your device and reboot. The phone will reboot twice, don't panic.
  • Enjoy root
I'll update this to a detailed version when I have time.
PS : I attached my constructed scatter file while waiting for the official one.
BV6800_PRO_MT6750_Android_scatter.zip
(1.36 KiB) Downloaded 808 times
slxx
Thu Nov 22, 2018 4:16 pm
thank, i can't believe i missed that.
I'll try asap and will keep you updated
Priyanga
Mon Feb 11, 2019 1:05 pm
Did anybody root successfully? If yes some more details.Thanks
sams
Mon Feb 11, 2019 2:49 pm
Yes. Just follow this procedure. Sorry I don't have time to write a super detailed one but you only need to search this forum for SP Flash Tool and how to use it (install drivers, extract boot, reflash boot).
Priyanga
Tue Feb 12, 2019 6:23 am
Small question.no need to unlock the bootloader?thanks
sams
Tue Feb 12, 2019 12:10 pm
no, you need to flash ONLY the boot image
Priyanga
Tue Feb 12, 2019 6:31 pm
Can i use the above scatter file for flash boot image for my phone?
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Users browsing this forum: No registered users and 10 guests
