Fri Nov 23, 2018 5:21 pm
			Thanks for your help but the open app doesnt make any difference.
Here is how the problem works: let's say, as an example,  I want to take a picture of a car and behind the car there is a wall. I will turn the camera on and aim at the car. The focus is fine, the car is cristal clear. But if I then aim at the wall, the camera will go out of focus and the wall will be blurry. If I then aim back to the car, the camera will still be out of focus and the car will also be blurry.
I will try to send some example pics, I haven't been successfull so far.
To reply to another post: no the phone or camera didn't get wet. It's brand new, sitting in my office, I haven't even put a sim card in it yet.
I have read that on some other blackviews there had been focus problems and it was solved with an update. Could this be the problem with mine?
I need the camera for my work, it it's not working correctly I won't be able to use the phone.
Any ideas are more than welcome.
Thanks
