noamco
BV2000 Cant turn on after photo with flash
Sun Jul 17, 2016 8:28 am
I tried to take a picture with flash set to on.
I tried to take the picture then the phone suddenlly turned off and since then i cant turn it on, no matter what i do. i tried to remove the battery, to charge it but nothing happen.
Please assist ASAP.
Thanks
Re: BV2000 Cant turn on after photo with flash
Mon Aug 15, 2016 6:51 am
noamco wrote:
Please assist ASAP.
Thanks
If your smartphone is still under warranty, please contact your seller for fix.
Best regards,
Admin
