Sat Nov 10, 2018 11:26 pm
I got it to send an MMS message in 3G mode finally. Don't know exactly what I did. From what research I've done, it seems the APNs are loaded from an internal android database of all providers, with the provision to have the carrier push custom settings. The LTE APN I have selected is missing the MMSC and MMS settings. There is a correct LTE internet APN but there is no radio button beside it to select it, and the messaging program doesn't seem to use it by default when it needs too. It's all quite frustrating. I'll contact my cell provider again, but the last time they just gave me the info to put in the APN. I would if I could.
I'd just like to know if anyone else can add/edit their APNs and if not, does the problem lie with the carrier or android?
