Neville
[USEFUL] SAFE MODE INSTRUCTIONS
Wed Oct 31, 2018 9:36 pm
These are the instructions to open your BV9500 in Safe Mode
Press and hold the Power button and select Power off to turn your device off. Press and hold the Power button, until you see the Blackview logo appear. Release the Power button, and press and hold the Volume down button. Keep holding it until your device boots up. You can let go when you see the words “Safe mode” in the bottom-left corner.
Ramrod
Re: SAFE MODE INSTRUCTIONS
Wed Oct 31, 2018 10:23 pm
Thanks for the info. Sorry to show my ignorance but when should we want to use safe mode?
phoenixkk
Wed Oct 31, 2018 11:58 pm
Thank you,
Thu Nov 01, 2018 9:16 pm
Safe mode will disable all the apps you installed. It is needed if your device has issues and you want to know if they are caused by one of the installed apps.
Ramrod
Re: [USEFUL] SAFE MODE INSTRUCTIONS
Fri Nov 02, 2018 8:39 am
Good to know. Thank you :)
