piruct
[SOLVED] No Charging over 83% after Oreo Upgrade
Tue Jul 10, 2018 8:19 am
what about charging?
All function go right but charging over the 83%
flashlight are ok
Re: No Charging over 83% after Oreo Upgrade
Wed Jul 11, 2018 7:56 am
Did you perform a factory reset after the update?
Can anybody else confirm such issue?
piruct
Wed Jul 11, 2018 9:39 am
Hi, yes I'd performed wipe reset to default after upgrade firmware.
Battery drain very fast, more then 7.0.
Also I returned to 7.0 because my sim stopped to work, I'd write a new post about this problem.
I think that we need a best quality upgrade to have a normal use (and usefull) of our smartphone.
anoopdw
Wed Jul 11, 2018 10:30 am
I am also having issues with my Blackview BV8000 pro after oreo upgrade (black view-bv8000 pro_2018062921_s21v57c2k_jk_tee-ota) and having the below issues:
1. Sim has stopped working after the upgrade which has made the phone unusable.
2. Charging very slow and takes almost 2-3 hours  from 30% to 100%
can you please let us know the resolution to these asap.
Thanks
Anoop
Wed Jul 11, 2018 7:45 pm
anoopdw wrote:
Thanks
Anoop
Fix will come soon by updates ;)
anoopdw
Fri Jul 13, 2018 8:00 am
blackview_admin wrote:
anoopdw wrote:
Thanks
Anoop
Can you let us know by what date can we expect patch  release the fixes to the above Android 8.0 issues.
Sun Jul 15, 2018 12:36 am
anoopdw wrote:
Thanks
Anoop
No ETA at the moment, but tech team is aware of that.
Sun Jul 15, 2018 12:37 am
Can anybody else confirm the 83% charge limit bug after the Oreo upgrade?
Santpj
Sun Jul 15, 2018 8:14 am
No problem for me.
100% here.
Luke
Mon Jul 16, 2018 2:30 pm
I noticed something connected to this. In the previous version, LED was turning green when battery reached 100%. Today I noticed it was green when battery was charging and around (above) 90%. It this behavior intentional?
I'm a software developer, see my projects if you're interested.
