AERO
Touchscreen doesn't work while charging!
Wed Jun 20, 2018 7:21 am
Hello, I have a problem with my P6000, it's working well but when i put it on charger, it becomes very hot.
I use the original Blackview charger, with blackview cable i had in package.
I checked in droid Info, between 42 and 45°C. And when the mobile is hot i cannot use my touchscreen!
It's simple, touchscreen is not responding! I have to wait him to cool down.  :shock:
To be honest it's a very good mobile but this problem is really annoying.  :evil:
Re: Touchscreen doesn't work while charging!
Wed Jun 20, 2018 8:25 am
Can you please perform a factory reset and try to charge your phone just after that?
This behaviour is not normal, but running apps in background while charging may rise the temperature a lot.
AERO
Mon Jul 22, 2019 10:52 am
I still have the same. I think because of the overheating while charging.
Best solution is : don't use the phone while charging.
