Linuxman
Android 6 Language to Polski after SIM insert
Wed Jul 06, 2016 12:31 pm
Hello Blackview Users
I have a problem: When I put my Swiss Mobile SIM into the BV5000, the language automatically turns to "Polski".... This language was the "standard", when I started the phone the first time. It doesn't keep my language "German". This problem appers with this SIM Card on both slots.
AND the Language changes with the Swisscom SIM Card to "German (Austria)" instead of my selected language "German (Germany)". I don't know if this behavior only appears on the Android 6 or on the Android 5, too...
When both Cards are inserted, the language changes first to "Polski" and then to "German (Austria)" (it takes a few seconds). BUT NOT "German (Germany)"... STRANGE
Without any SIM Card, the language seems to be OK (no changes).
I hope you understand my English and please help me :)
Greetings from Switzerland.
Re: Android 6 Language to Polski after SIM insert
Thu Jul 07, 2016 8:45 am
This may be a problem about software, you may need a firmware update.
Best regards,
Admin
lizard79
Sun Mar 05, 2017 4:46 pm
I have similar problem, I am using the latest stock Android 6.0 ROM, BV5000 C1 V1.6 downloaded from BV site.
I tried to open new topic about the issue already 2 times, maybe here I can submit the problem...
In short I am using my phone with hungarian language with a finnish SIM1 and a german SIM2.
In case of restart, shutdown or airplane mode the system language is changing to the default language of SIM1 -> finnish
New observation, in case of roaming the language changes also to finnish, without restarting or any interaction with the phone.
I have PIN set for SIM1, maybe it helps you to develop solution.
Users browsing this forum: No registered users and 10 guests
