Tanzit
enable VoLTE + other
Tue Jun 05, 2018 11:11 am
I notice that when I call somebody, the phone switch back to 3G, I deduce that there is no VoLTE enabled...
I'm on orange France network, is there an option to activate ?
Other issue, since few day, when I do a deep clean, I have an error message with the setting windows remaining (system interface has stopped working...) ? Bug corrected in next OTA ?
Just a last question, which type of screen protection is on this phone: which version of Gorilla glass ?
Thanks in advance for your reply...
Regards
Re: enable VoLTE + other
Wed Jun 06, 2018 2:21 pm
Hi there!
1) You should be able to enable VoLTE in the mobile network settings. It is called "Enhanced 4G LTE" or something similar. Remember that VoLTE should be supported also by your carrier and coverage...
2) What deep clean are you talking about? can you take some screenshots please?
3) It should be Gorilla Glass 3
Tanzit
Wed Jun 06, 2018 11:31 pm
Here is the type of deep clean I do (screenshot)...
thanks
Thu Jun 07, 2018 10:06 am
Yeah, it looks like a little bug wich will be fixed soon ;)
Tanzit
Fri Jun 08, 2018 10:41 am
thanks for your return...
Concerning the VoLTE enabling, the VoLTE is not available on Orange France for this model of phone, only fo Iphones, Samsung models and few others...
Tanzit
Wed Sep 19, 2018 9:23 pm
I have read on other forum than there a question of CSC.
It could be possible to modify it on a rooted phone...
Could you make it VoLTE compatible for the next update ??
Regards
Thu Sep 20, 2018 10:54 pm
Regards
VoLTE compatibility relies on the phone carier. We can't make anything for that, unfortunately.
Tanzit
Sat Sep 22, 2018 6:42 pm
:( thanks anyway  :(
dascalumrn
Sat Oct 27, 2018 5:50 pm
Volte Enable
