McSNox
Re: OTA update error 20180426
Thu May 17, 2018 8:03 am
Blackview, please make OTA on 2017.07.08 or local firmware, which can be installed without a computer for firmware 2017.07.08
Blackview BV6000 V01_20170708
bvbw
Fri May 18, 2018 5:27 am
Hello Admin,
No news about flashable version 20180426 ?
Thanks.
damingara
Mon May 21, 2018 8:55 am
blackview_admin wrote:
Hi! try to re-format your SD card to be portable storage (not internal storage) and report back if this fixes your issue.
Same issue with me. Memory card as internal storage: failed update.
Then formatted as external, tried OTA again and: finally it worked.  :D
But now i have to bring back music and fotos to the phone.   :shock:
I suggest for future updates to ignore the system-default writing memory and hardcode the use of internal memory.
Greetings and thank you for still updating the device!
McSNox
Mon May 21, 2018 3:09 pm
When will there be an update from the firmware 2017.07.08 ???
Well, there is no way to upgrade using the computer.
Please do some transient local update.
Wertos
Tue May 22, 2018 5:51 pm
And why does 20180515 someone flies, but who does not?
Fri May 25, 2018 5:17 pm
McSNox wrote:
When will OTA be for firmware 20170708 ???
How can I upgrade to the latest firmware without a computer ???
Why did you again throw half of your users ???
Not everyone has the opportunity to update through the USB flash drive
1) OTA updates can't be predicted. They don't reach every user and don't reach every user at the same time
2) Performing an OTA update, obivously
3) ?
4) Nobody can update and Android device with an USB flash drive....
HelloWorld
Sat May 26, 2018 4:08 am
2a-If the Admin uploads the OTA update, you can download the file to the phone directly and then do a local update using the update app you also use for OTA updates :ugeek:
Ickabod
Sat May 26, 2018 12:44 pm
Hello Admin, my BV6000 doesn't OTA anymore. The installed version is V01_20170708. I tried to do a local update with newer versions e.g. 20180330 and it started to update but failed after a few moments. The phone restarts with the old version. PC-update with Windows 10 doesn't work because of microsoft security reasons.
How can I update the phone? Please help.
Frank
Sun May 27, 2018 3:38 am
LOCAL UPDATE isn't working correctly, unfortunately.
OTA or flashing are the only choice at the moment.
custal
Sun May 27, 2018 11:40 am
Yea, and OTA doesn't work properly either. Great.
So, basically, if you have 20170708 installed, you are stuck.
