valda84
Cannot update ROM
Thu Apr 05, 2018 7:29 pm
I try to update my phone. I downloaded ROM 20170223 to my phone, open the update via local file. Phone restarted, looks like it is upgrading, but after start up, nothing happens. The version of ROM is still the same.
Can anybody help what to do with it?
My actual ROM is 20161216. But do not work properly. I have some problems with sound.
Thank you very much
bvbw
Re: Cannot update ROM
Thu Apr 05, 2018 9:11 pm
Why you don't flash the last ROM ?
In all cases if sounds problems come from material speaker defect, upgrade ROM will not change nothing ...
Check before if you have problems also with headset.
valda84
Fri Apr 13, 2018 6:34 pm
I cannot upgrade on any other newer version. Still the same problem. Flash via computer doesnt work for me, I dont know why.
I do everything as it is in manual, but phone do not connect to PC. It always disconnect, after few seconds.
HelloWorld
Sat Apr 14, 2018 4:49 am
Have you also tried the local update? Eg download to phone and then flash? As the PC route does not work, you probably will not have TWRP or anything else preventing it from working...
Sun Apr 22, 2018 10:31 am
I suggest you to move to another PC and start again from the beginning!
Priyanga
Sun Apr 22, 2018 2:38 pm
Load the rom to flash tool press download..then power off the phone connect usb cable to pc while holding vol down button.
Tue Apr 24, 2018 8:55 am
+1
