kevinragoonanan
type C to HDMI
Thu Mar 22, 2018 1:07 pm
hello, can i get a link to a type c to hdmi that will work for the bv7000pro please?
i tried a few and they didnt work
Re: type C to HDMI
Fri Apr 20, 2018 8:15 am
The BV7000Pro carries a deeper than standard usb-c port, so you'll have to use a longer than standard usb-c cable head.
Considering that an USB-C longer head / HDMI adapter cable doesn't exist, i suggest to use the OTG cable wich came out of the box together with an HDMI/USB adapter ;)
