Roman150779
BV9000
Sat Feb 03, 2018 5:22 am
Good afternoon. I bought the phone BV9000. I did not work the phone app. Writes: In the application "phone" failed. I can't make calls! Only call the contacts on the SIM card. Please take action, and fix it in the update. And I can't hear... can speaker?
Re: BV9000
Fri Mar 30, 2018 1:43 am
hello,
what is your firmware version?
you can try to enter the factory mode to reset your device.
here is the guide link:
viewtopic.php?f=192&t=334922
