AERO
BV6000 after 16months
Wed Jan 31, 2018 8:32 am
I had a BV6000 for 16 months, he did the job.
I never had big problem with it, maybe a reboot sometimes but nothing wrong.
I had also problem with screen when it was dirty or wet, it was not working properly but after cleaning it was okay!
I used it in shower or in swimming pool very often, and yes it's a waterproof mobile. I never had water problem with it.
It's still working today, and I think it's more reliable than a samsung or apple.
That's why I took an other blackview, my third one : the P6000. ;)
I changed because I wanted to change for something more powerful.
Morpheus
Re: BV6000 after 16months
Mon Jul 13, 2020 11:48 am
I purchased the bv6000 pre order from AliExpress way back then and I also still have mine and it is still working very well. I had some issues along the way but for the most part it was worth it and I'm still loving the device, and I got a few different devices since then including the Samsung Galaxy s8 active but I just received my Blackview bv9800 pro and expect nothing less than several years of great usage from this device as well.
