lucky1guddi
Re: [TRACKED] BV8000pro camera became very noisy and poor after 20171227 update
Thu Apr 26, 2018 11:46 am
Hello Admin, But what we do to improve our camera quality we are facing very serious situation when we take photo among our friends and tell him that this is 16MP Camera. Please do some solution or update
Fri Apr 27, 2018 8:17 am
First, learn how to take photos with smartphones ;)
This topic may be useful:
viewtopic.php?f=191&t=345515
About the noisy camera after the 20171227 update, tech team is aware and a fix will come.
lucky1guddi
Sat Apr 28, 2018 12:13 pm
I already used these setting but it get blurry picture always. Can i install any previous update in which you fix the blurry issue.
Sat Apr 28, 2018 12:58 pm
Yes, you can downgrade to previous versions. Just flash the ROM you want.
lucky1guddi
Mon Apr 30, 2018 5:58 am
I flashed in previous version as I discussed earlier but still photo blur issue not resolved and the pic not so clear as expected from 16MP camera. not happy at all
Tue May 01, 2018 9:27 am
Did you perform a factory reset after such downgrade?
You can downgrade to previous firmwares until you want, just try.
lucky1guddi
Wed May 02, 2018 5:30 am
Yes, I perform a factory reset after downgrade
Wed May 02, 2018 12:34 pm
Try to downgrade to earlier firmwares.
lucky1guddi
Thu May 03, 2018 5:47 am
Ok please you may suggest which one solve my problem
Fri May 04, 2018 9:33 am
Just go back until your are satisfied ;)
Don't go back more than the 20171114 version.
