admin
Site Admin
A7Pro flash rom download links
Sat Nov 18, 2017 2:49 am
A7Pro_blackview_20171031 to optimize the icon and camera.
https://mega.nz/#!MToijJDS!1bS1gFXlUekR ... kBW8a7DfHk
ufos97
Re: A7Pro flash rom download links
Sat Nov 18, 2017 2:26 pm
Please how do i go about the upgrade because when i tried it sp flash tool showed this
S_BROM_DOWNLOAD_DA_FAIL
[Description]
l [H/W] Fail to download DA to baseband chip's internal SRAM!
[Reason]
1. There’s a cable communication problem between Flash Tool and Boot ROM.
2. Target might be shutdown unexpectedly or target lost power supply.
3. The DA is not correct.
[Solution]
1. Try again.
2. Proceed H/W checking in download cable and target side com port.
3. Monitor if power-drop occurred in target side.
war_horse
Sat Nov 18, 2017 5:40 pm
flashed on my a7pro it works like a charm
Roller
Tue Nov 21, 2017 12:40 pm
Would it be possible for the file to be uploaded to an alternate mirror? I can't download from Mega.
jps71
Tue Nov 28, 2017 5:56 am
Hi
I have just purchased a A7 pro & found this forum.
Can some one please tell me what this flash rom is, do I need to install it, if so how do I install it.
Thanks Jps71 :)
zimzia
Wed Nov 29, 2017 8:26 pm
how to update? local update or flash tool ?
zimzia
Fri Dec 01, 2017 6:44 am
is anyone here ??
Fri Dec 01, 2017 7:46 am
zimzia wrote:
is anyone here ??
Sp Flash Tool will need to be used.
zimzia
Sat Dec 02, 2017 6:55 pm
Manual ?
shahardemos
Mon Dec 18, 2017 2:35 pm
I failed to install in manually on Windows 10 with SP_Flash_Tool_v5.1728_Win.
Drivers were installed but using the original USB cable flash tool complained and didn't flash.
Any chance of having an OTA available soon?
