Chichoun
How to insert a memory card with 2 SIM cards ?
Tue Oct 17, 2017 10:22 am
I have a P2 Lite phone with 2 SIM cards and I don't find a third slot to insert a memory card.
Could you please explain how and where to insert a memory card in the P2 Lite phone ?
Thanks for your support.
Kind regards,
Chichoun
Re: How to insert a memory card with 2 SIM cards ?
Wed Oct 18, 2017 1:48 pm
Sorry, you can insert only two sim or one sim and one SD card into this phone.
Chichoun
Fri Nov 03, 2017 2:11 pm
Thanks for your reply.
I think this is a pity and at least unfair from Blackview company.
Indeed, this limitation is not indicated at all in the available information in Blackviews,s web site !!!
I would have never bought this device knowing this limitation. I feel duped by Blackview... :(
Mon Nov 27, 2017 5:39 pm
If you look at the sim slot, you will see 2 sim holes, the one closest to the phone has a little notch for a microSD, no dupe, just a hybrid tray
