Re: [TUTORIAL] Flashing your BV8000Pro to the latest firmware version
Tue Jul 10, 2018 3:49 pm
Aksl wrote:
blackview_admin wrote:
Just use the second local update method written here:
viewtopic.php?f=192&t=436084
Hello, i have tried to perform the update with the second method as you have recommended, i copied the firmware zip file to the main directory, removed the external sd flash card, rebooted in recovery, selected "apply update from sdcard", and it gave me  a message in the middle of the black screen "Supported API: 3", than a few seconds later, it brought a message on the top of the screen in red:
 Choose a package to install:/sdcard
And that`s all, no choose of the package, nothing, empty. All thaw i know that i have copied the firmware to the main directory, where all files are android, data, download, the main, main directory.. ((
Try to perform a factory reset of your actual system and try again with the first or the second local update methods.
Aksl
Tue Jul 10, 2018 6:25 pm
Yes, i did that, still same behavior, i guess i will wait for air update. Thank you
Rgaspar
Tue Jul 10, 2018 6:56 pm
Aksl try to downgrade to a previous version (20171219 for example) and only then try to install via recovery
viewtopic.php?f=224&t=436576&start=10
aschitaka
Wed Jul 11, 2018 12:36 am
Hello is no possible downgrade
adb reboot recovery   the command tell me this if  NO COMMAND
Aksl
Wed Jul 11, 2018 7:20 am
Hi Rgaspar, thank you for the note, on the first page of the theme by your link, message from michele.mignini, who adviced to wait for the stable firmware, because the present isn't perfect. What are the bugs in the present one?
Tristan
Thu Jul 12, 2018 3:13 am
It doesn't work for me. As told on other topic, I downloaded 2 times the zip. Put them on différents folders. Used the 2 methods. But nothing
Try to put the .zip file on your phone without sdcard.
There does not appear to be a way to navigate to the file ion the phone only if f it is on the SD card when you are in android recovery mode
djspeed21
Sun Sep 02, 2018 4:11 am
The Checksum Generator link is dead. Anybody have a new link?
Naks
Sun Sep 02, 2018 1:45 pm
Can confirm, the link is dead. Anyone got a backup?
Sun Sep 02, 2018 11:08 pm
Here you go!
https://www51.zippyshare.com/v/hjhS0chN/file.html
fredx30
Tue Sep 11, 2018 11:25 am
I downloaded both the 8.0 official rom and the checksum generator but i cant seem to get a match this hasnt been a problem for me in the previous version. Any tips anyone got this working?
