vitubandeira
Re: [TUTORIAL] Flashing your BV8000Pro to the latest firmware version
Fri Feb 23, 2018 4:51 am
serattok2 wrote:
There is no error message, but the process percentage is no more than zero.
Can someone help?
Same problem!
kavedel
Fri Feb 23, 2018 6:12 am
I insist that all of you having problem updating by using the tutorial to have a look at this:
https://romprovider.com/2017/07/firmwar ... v8000-pro/
vitubandeira
Fri Feb 23, 2018 4:41 pm
I got it!
But not with the SP MultiPort, i got it with the SP Flash Tool.
Now i'm with 20180124.
Sat Feb 24, 2018 3:16 am
vitubandeira wrote:
I got it!
Great! ;)
Remember to perform a factory reset even after flashing!
yiannisf
Mon Mar 19, 2018 4:03 pm
Hi all,
I have just manually flashed my BV8000Pro as per the instructions with the rom version BV8000Pro_blackview_20180308. Or at least I think I did. The procedure seemed to have worked just fine, and after the SP Multi-port finished successfully and I started the phone I was with a clean installation and everything seemed ok. However when I go on settings > About phone the build number on the bottom reads "BV8000Pro-Blackview-V0.1_20170803" and if I go yo wireless update it reads that the current version BV8000Pro-Blackview-V0.1_20170803_20180307-1950.
Is that correct?
Also, did I have to install all the ROMs since my current version or would only the last version suffice?
I am really sorry if all these questions have already been answered, but I went through a lot of pages and did not find an answer.
khaqanson
Tue Mar 20, 2018 3:25 pm
yiannisf wrote:
Hi all,
Is that correct?
Everything you stated is perfect. If you install the latest ROM there is no need to install date-wise upgrades. The Latest Rom always has the best options previously released.
As far as Rom version is concerned , its always described in wireless update section and in your case its already been updated. So everything at your side is perfect
Tue Mar 20, 2018 3:27 pm
yiannisf wrote:
Hi all,
Is that correct?
Your firmware version is correct ;)
Updates are incremental: latest version carries all the previous updates ;)
yiannisf
Wed Mar 21, 2018 9:06 am
Thank you both, very much! :) :)
Tristan
Tue May 29, 2018 2:11 pm
I tried both methods and the transfer never started
Checksum was good
The only issue I had was at first my PC say the phone was a blackview 8000 pro, then it said phone not recognized.
I tried it with the phone off and plugged in and with the volume up button pressed until I got the menu
Any advice to get the transfer to start?
Wed May 30, 2018 2:14 am
Checksum was good
be sure to STRICTLY follow the tutorials posted at the beginning of the topic.
If you can, try also on another PC.
