  • 1
  • 2
  • 3
  • 4
  • 5
  • 16
[TUTORIAL] Flashing your BV8000Pro to the latest firmware version
Sat Sep 23, 2017 10:11 am
In the attached PDF file below you will find a simple flashing tutorial for BV8000 Pro.
You can also use the tutorial by Mino:
https://drive.google.com/file/d/15-1vyR ... zEchI/view
Before you start flashing, please make sure to have clearly understood every step and how to perform it correctly.
This is the new checksum generator download link:
https://gofile.io/?c=iOe82h
flashing-8000pro_v3.pdf
(332.01 KiB) Downloaded 11654 times
lollon82
Re: Simple Flashing Tutorial
Fri Sep 29, 2017 4:22 pm
I tried the steps above, but the programs says it misses an INI file for checksum.
i downloaded the CheckSum_Gen.exe, witch does nothing.
How can i bypass it, or make it work?
thanks
oaimng
Sun Oct 01, 2017 6:33 pm
I tryed to flash using the tutorial, but not succesfull, the phone won't turn on, the proximity red sensor si blinking constantlly. I think is bricked. What can I do to bring it back to life?
video with the phone blinking proximity sensor:
https://youtu.be/ojkbun3KkbQ
EDIT:
It turned on after waiting 30 minutes.
this is the screen shot of the erorr I get when following your tutorial:
the error occured at this step from the tutorial:
7) Press “Start all”. Press Phones volume-up-key while connecting it again.
Do you know what I can do to fix this error and flash the previous version of 20170822 of the bv8000, because I have 20170829 and is a bugged update, I can't have a decent phone call because of this, details on this thread: viewtopic.php?f=191&t=295844&start=10
MB242
Mon Oct 02, 2017 6:07 am
I had no issue using SP Flash Tools.
war_horse
Mon Oct 02, 2017 9:39 am
you must download checksum generator tool, extract all the content of the archive inside the folder where the scatter file is located, and execute checksum generator, once you have done this operation everything will work like a charm.
The rom downloaded miss the Checksum.ini that assure the integrity of the download, so SPMD tool don't allow you to continue to the next step.
MB242
Mon Oct 02, 2017 10:28 am
war_horse wrote:
The rom downloaded miss the Checksum.ini that assure the integrity of the download, so SP Flash tools don't allow you to continue to the next step.
You probably mean SPMD tool not SP Flash.
war_horse
Mon Oct 02, 2017 10:30 am
yes sorry for the mistake i mean SPMD tool :D , i ll modify the post
MB242
Mon Oct 02, 2017 11:05 am
Might be confusing ;)
Typhoon29
Wed Oct 04, 2017 8:12 pm
Updating and bug fixing sounds very technical and if like me you lack experience, would you recommend taking it in to a repair shop to get the phone updated?
oaimng
Thu Oct 05, 2017 6:01 pm
Hello guys, tryed a lot of checksum.ini generators, none worked until I looked and found one at this post:
viewtopic.php?f=192&t=320735&p=532492#p532492
  • 1
  • 2
  • 3
  • 4
  • 5
  • 16
