Danntattoo
Screen crashed display off
Tue Sep 19, 2017 7:25 pm
I bought a Bv7000pro and fell with it in his hands, and the screen simply splintered and the aluminum side was out. I am with him 4 months and I need to know what to do because I live in Brazil and bought the device precisely because of the resistance. How to proceed?I can not ask for support in "contact us", says that the email is not valid . Show this E-MAIL FAILED TO SEND.
Re: Screen crashed display off
Thu Sep 21, 2017 9:05 am
You can buy a new LCD and/or Touch-Screen on platforms like aliexpress. I suggest to buy LCD + Touch digitaliser together because they are hard to separate. You can repair it by your own or go to a local mobile repair store.
https://www.aliexpress.com/af/bv7000-lc ... =200005298
Danntattoo
Wed Oct 04, 2017 10:47 pm
thank you, will you get the link with the sides of aluminum and buttons, because on the other side the right side released and lost the screws too
Kiranacantik
Wed Oct 11, 2017 2:55 am
is there any shop where to sell lcd + touc bv 7000 pro in indonesia, because i also experienced no display screen.
Tue Oct 17, 2017 2:41 pm
you can buy from different aliexpress sellers: https://www.aliexpress.com/wholesale?ca ... for+bv7000
