ashboe
Micro USb or type C?
Sat Sep 16, 2017 11:13 am
'Now the Blackview P2 uses microUSB but it looks like a USB Type-C port, so the charging on it should be the same as a standard Micro USB cable, but the difference here is that this cable can be plugged in even if you flip it upside down just like with USB Type-C. So while it won’t really charge any faster or support the same specs as USB C, it does have the benefit of being able to plug in right-side up or upside down'
I have heard it said that the P2 uses a type C port - which is it?
Re: Micro USb or type C?
Tue Sep 19, 2017 10:04 am
As far as I know the phone have a USB-C Port! I tested and could use it with every usb-C cable without problems.
Stratosphere
Tue Oct 17, 2017 8:25 am
Mine is definitely USB C.
