Anwar30
3G support
Thu Jun 09, 2016 1:02 am
I want to ask one thing that I want to use 3G for GSM network not for WCDMA network. Can I use it on Blackview A8.
Re: 3G support
Sun Jun 12, 2016 8:04 am
blackview_admin wrote:
For GSM network, it supports 850 900 1800 1900MHZ
For WCDMA network ,it supports 900 2100Mhz.
you'd better to check with your nerwork carrier if the above network frequence can match your need.
Best regards,
Admin
