A5 ROM Download link
Thu May 26, 2016 8:32 am
Dears users,
There is the latest rom of A5 for you, and anyone in need can download via the following links.
But before you download , please finished reading the following guides.
1) Check the software verison number in the device, if the version date is before May 3rd, then download the following one :
https://mega.nz/#!3t9RQRyZ!PJb3YPreGL6f ... 4AfwbH5Vlg
2) Otherwise, this one below will be suitable for yours:
https://mega.nz/#!v8sVAQLY!TnRgieY3rYSl ... Hc0xnW2HNY
And the check is very important, it can help you avoid flashing a wrong version rom, which may cause the improper work of your smartphone.
valin
Re: A5 ROM Download link
Tue Jun 07, 2016 8:04 am
What are the differences between the versions?
Thanks.
valin
Tue Jun 07, 2016 8:05 am
Thanks.
DVDDMD
Sun Jun 19, 2016 8:31 pm
Hello, this is what I see in my phone. I must then choose ROM number one, ¿correct?.
Any tutorial on how to flash the ROM? .
Thanks.
Tue Jun 21, 2016 8:03 am
Thanks.
no actual differnence, just considering the compatibility and suitability.
Best regards,
Admin
DVDDMD
Tue Jun 21, 2016 3:08 pm
Hello, this is the third time i try to post, but messages never appear. Help
SiJosepa
Женщины
Tue Jun 21, 2016 9:10 pm
Если нет охотников петь дифирамбы своему начальнику, значит, его песенка спета.
Wed Jun 22, 2016 8:30 am
Thanks.
yes , number one will be suitable for yours.
Best regards,
Admin
Tolovendo
Fri Jun 24, 2016 5:49 pm
I have problems with the touch.
It's too sensitive and hard to use.
Now the down side near home doesn't response good.
Could be this solved with a new firmware?
When will be a newer firmware?
DVDDMD
Mon Jun 27, 2016 7:53 am
Thanks.
Best regards,
Admin
Thanks. How can I flash it? Vía pc or it is an internal Phone process?
