sokolov
lost network A8
Wed May 25, 2016 6:48 am
Help, I lost signal on any simkarty ! " Connection problem or invalid code for the MMI " switch from 2G to 3G is the same ! You may need to flash the communication module ?
Re: lost network A8
Fri May 27, 2016 7:03 am
You mean you can not get a network connection ?
Have you try your sim card in other smartphone, may be the network service of your simcard fails.
Best regards,
Admin
