ashboe
SD Card
Fri Aug 11, 2017 2:11 pm
any one have a SD card as well as a sim - whats the largest SD card the P2 will read?
d8smt
Re: SD Card
Sat Aug 12, 2017 6:40 am
mine is running fine with a 128GB Sandisk card
pfavayi
Re: SD Card
Sun Aug 13, 2017 11:46 pm
The P2 takes the micro SDXC card. That card can go (from 32GB ) to 256 GB
But it will be formatted extFAT or you have to format it extFAT . Fat32 will not work.
It can also take micro SD (max 4GB)
Or the Mico SDHC (max 32GB)
