Ardi Koto
My BV7000 7000 pro Won't Charged
Wed Aug 02, 2017 3:15 am
My Bv7000's do not charge battery, before i use this smartphone until battery show 0% number. After that when i tried to charge the battery, this smartphone wan't to charge. I want a solution from bv7000 party. Please help me. :cry: :(
I'm so sorry if my English is so bad.
I'm from Indonesia.
Re: My BV7000 7000 pro Won't Charged
Mon Aug 14, 2017 3:38 pm
It seems your battery is defective and must be changed. Please contact your seller for that.
grAwp
Wed Jan 10, 2018 11:16 am
Or try another charger and another charger cable. Make sure if you right connect the cable into the phone. If this not help you can buy a new battery from ali.
cheucheu
Mon Sep 17, 2018 10:01 am
Hello
I can't charge my phone.
I check the original cable and it's OK.
Where can i find a new battery ?
BR
Weaving
Wed Sep 19, 2018 10:19 am
Try charge your phone with powerbank. I have sililar problem. Start charging with powerbank about few minutes and continue charge classic with wall adapter.
