Holefighter
Power button dont work anymore.
Tue Aug 01, 2017 3:22 pm
Suddenly my power button dont work anymore. I open the phone and when i push the power button without the panels in the side sometimes the button works. But only if i push very hard. What can i do?
Gazaa
Re: Power button dont work anymore.
Wed Aug 09, 2017 11:39 am
Jai le meme souci avec mon bv7000pro apres une après-midi baignade le bouton alimentation ne fonctionne plus correctement je dois appuyer tres fort
Jai opté pour la solution suivant
Active dans les paramètres ONE HANDS FLOAT VIEW
et suis le guide j'espère que sa pourra taider :)
Holefighter
Thu Aug 10, 2017 5:06 am
Thanks, but woth the float view i only can lock the phone bot restart right?
Thu Aug 10, 2017 6:08 pm
Maybe you can try to place a little peace of plastic between button and it's contact to make the press harder.
But if nothing helps you can of course also ask your seller for repair or exchange. Only if he don't help you please contact us.
