thomasss
Use the touchscreen witn wet fingers
Tue Jul 25, 2017 1:42 pm
I am about to buy a BV 7000 or 7000pro. And I just would like to know if it is possible to operate the touchscreen with gloves and /or wet fingers.
Thank you for your answers ! ;)
Thomas
Re: Use the touchscreen witn wet fingers
Tue Jul 25, 2017 2:15 pm
There is no special glove mode but in my tests with wet finger and thin working-leather-gloves it worked well.
Of course with bigger lined gloves it can not work.
thomasss
Tue Jul 25, 2017 7:07 pm
Thxs for your answer.
The main goal for me is to be able to use it while running or biking even if it's raining ...
I red that the Kyocera Torque, the Nomu S30 or the Croscall Trekker X3 (with "wet touch" fonction) can operate even if raindrops fall on the screen.
Is it due to the quality of the touchscreen (Gorilla Glass 3 - Glass 4 for the Crosscall -) ?
thomasss
Wed Jul 26, 2017 7:40 am
Thxs for your answer !
My main goal is to be able to use my phone while running or biking even if it's rainy and if there are raindrops on the touchscreen.
I know other phones that allow that (Nomu S30, Hisense C30, Kyocera Tporque, Croscall,...) but the BV7000 is for me the best value for money.
Is the gorilla Glass 3 touchscreen the key factor that allows these phone to operated in such weather conditions ?
Fri Jul 28, 2017 8:04 am
thomasss wrote:
Is the gorilla Glass 3 touchscreen the key factor that allows these phone to operated in such weather conditions?
Sorry, I don't know what makes the difference.
Holefighter
Fri Jul 28, 2017 6:53 pm
Today i try iT in the pool. I habe no problems underwater
