ococ
Incorrect battery information.
Sat Jul 08, 2017 12:28 pm
Hello.The software version is installed on your phone.P2lite_blackview_201706221607.The phone is reset to the factory setting.The battery is charged 100%, the phone is uncharged.Using the phone for several hours, the percentage of battery charge does not change.
In the engineering menu there is no information about the battery. To measure the voltage and current of the battery was a third-party program. The voltage of the battery is 4.38 -100% of the charge. The voltage drop is up to 4.20 -100%. This is not correct !!!
Ldimosa
Re: Incorrect battery information.
Wed Jul 26, 2017 7:27 am
В телефоне батарея не соответствует заявленной, 4800 mA max
Wed Aug 02, 2017 11:16 am
I will report this bug
nesterov32
Sun Aug 13, 2017 3:35 am
Good afternoon. Also confirm this error. We need to release a new firmware.
Mon Sep 18, 2017 5:31 pm
Had you tried a factory reset?
