GeorgeD
Phone Heat Up fast
Thu Dec 24, 2015 5:31 am
Hi Friend,
I just bought 5 days ago, an Omega Pro but when I start using 3G internet surfing or within 5 minutes surfing internet the phone heats up on back side of the phone, but when I keep on with 3G without surfing internet does not heat up, Also while using WiFi too does not get heat.
kindly advice do I need to contact the seller or other solutions.
Thank you & B. Regards,
George
Seasons Greetings for all
Re: Phone Heat Up fast
Thu Dec 24, 2015 6:24 am
Hi ,
Thanks so much for your post and feel so sorry to hear that problem.
Except this problem ,everything is ok with you phone ?
Best regards
Admin
GeorgeD
Fri Dec 25, 2015 9:25 am
Dear Friend,
Thanks for your query,
yes Everything fine it looks & works fine .........other than the phone getting heat very fast. so I had to stop surfing internet it may effect the whole phone
Thanks & B, Reagrds,
George
Wish you all Merry Christmas & a Bright year ahead in 2016 to all Balckview team & Fans
GeorgeD
Sat Dec 26, 2015 6:00 am
Hi Friend,
yes only the internet is very slow comparatively previous phone & heating up fast
other thank all are good fine,
B. Regards,
George
GeorgeD
Sat Dec 26, 2015 8:25 am
I am sorry I just today faced the sim cards connection lost & logoff buttons not function so cannot restart & little later comes to normal
this happens twice today as I noted, will advice if happen again
B. Regards,
George
Mon Dec 28, 2015 2:37 am
B. Regards,
George
ok !
Mon Dec 28, 2015 2:42 am
GeorgeD wrote:
Hi Friend,
B. Regards,
George
Hi ,
the problem will happen also when use 4G ?
GeorgeD
Mon Dec 28, 2015 3:23 am
Hi Friend,
I have not used 4G, only 3G
Kindly advise to resolve this issue,
B. Regards,
George
Tue Dec 29, 2015 6:59 am
GeorgeD wrote:
Hi Friend,
B. Regards,
George
then you may can try on 4G , because in some regions the 3G Signal is very weak , then it is easy for phone to heat up when use 3G to surf the net .
Best regards,
Admin
GeorgeD
Tue Dec 29, 2015 7:40 am
Dear Friend,
More than the speed the phone getting heat is the problem
how can we solve this
B. Regards,
George
