metalsgeorge
Re: Flash ROM of BV7000_PRO_Blackview_20170622 to upgrade 7.0 OS
Mon Jul 10, 2017 4:27 pm
What do I do to correct the error "Incorrect scatter file format"??,
during file opening "MT6750_Android_scatter.txt"
Tue Jul 11, 2017 1:22 pm
Be sure to follow the Flashing manual and select the correct file.
For this file you also have to execute the CheckSum_Gen.exe like shown here: https://www.youtube.com/watch?v=r9HXJH0H43oc
PS: and notice BV7000 and BV7000Pro are two different devices. Select the correct firmware file.
Pablo0208
Tue Jul 11, 2017 3:01 pm
flashing my phone now,
in the instruction PDF you need to remind folks to reboot the PC after adding the VCOM drivers,
else nothing will happen.
AND don't bother with the youtube vid, it doesn't bare any relation to what you do with the latest flasher, certainly not in Win 10. No mention in PDF of running the checksum in as per vid neither..
This spflashtool V5.1716 makes it so easy to do...
I now have android 7 - sweet
uwg+
Sat Jul 15, 2017 6:16 am
I followed the instructions here and everything is working without any problems. THX. 15.07.2017 :D
andrevg
Wed Jul 19, 2017 5:27 pm
As I can see here. We must be an IT specialist to use this phone, which I'm not. So, I'm giving up. I just need the phone for basic uses, and that includes wi-fi and bluetooth. Both doesn't work well, loosing connection all the time.
I'll buy another phone.
wim1974
Wed Jul 19, 2017 7:58 pm
I had some problems with flashing, the SP Flash tool got stuck at "DA download 100%", I tried several times.
I solved this by updating the Mediatek drivers from the device manager (when the phone was connected, power off). After updating the drivers, the flash worked perfectly
Vic_Aboe
Thu Jul 20, 2017 1:28 am
This is working, great. and than when i check for update, i get new notification for update version : BV7000 PRO_Blackview_20170706_20170706-0255 with size 154.29 MB
Is anyone get notification like that ??
Holefighter
Thu Jul 20, 2017 5:08 am
Yes got it too...
Derk
Thu Jul 20, 2017 6:53 am
That's the latest OTA update which installs smooth.
Holefighter
Thu Jul 20, 2017 5:57 pm
But what are the changes?
