  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 11
velmafia
Re: Flash ROM of BV7000_PRO_Blackview_20170622 to upgrade 7.0 OS
Sun Jul 02, 2017 5:33 pm
cheucheu wrote:
The link of this ROM is KO.
Could you repost the ROM ?
my ROM backup: https://mega.nz/#!lm4lSAAL!VKw9EYXTY7_W ... _T7nIAfFh4
but I don't know why link from admin post is unavailable.
BR.
cheucheu
Sun Jul 02, 2017 7:40 pm
Thanks a lot
Your link is valid. How to backup your mobile before the upgrade ?
Have you a tool ?
BR
velmafia
Sun Jul 02, 2017 8:06 pm
Have you a tool ?
As far as I know you can use SP flash tool (flashing tool- "Readback" bookmark), you can find tutorials in google.
BR.
karera
Sun Jul 02, 2017 9:19 pm
will they release an update for android 7 builds? there are problems in my Blackview BV7000 Pro like system ui crashes, some apps closes, etc...
Timmy96
Mon Jul 03, 2017 6:07 am
Hi friends, I have download the current link. But it ask for decryption key
bili
Mon Jul 03, 2017 4:21 pm
Dear admin, I found new problems, Battery phone lasting little with android 7, even less than android 6. Writing does not match well with the touch, the letter does not take what I want. I problem with some applications. Dice applications Interrupted. Do you have any chance of fixing these bugs?
Charlysan2
Mon Jul 03, 2017 6:59 pm
Derk wrote:
blackview_admin wrote:
Charlysan2 wrote:
Hi, the technical sheet of the MT6750T says it can operate on all 3G and 4G bands. Please Admin, I will confirm if Blackview will update the firmware to activate the bands 3g in B2 and B4, as well as in LTE bands B2 and B4. Thank you.
Sorry, there is an other hardware limitation that don't allow us that change on current devices.
The main reason will be that it costs royalties to unlock an LTE band and makes the phones higher priced. So no manufacturer will do this after sales...
Hi, Derk, so if I can do the root can I activate those bands via software?
karera
Mon Jul 03, 2017 8:08 pm
Do you know the difference between Download Only, Firmware Upgrade and Format All + Download in SP Flash Tool?
spit4brains
Mon Jul 03, 2017 8:21 pm
Hi i cant upgrade to os 7 dont know if it is the phone or pc, sp flash just scans forever (30min+) and finds nothing however if phone is switched on sp flash says scan failed. The MTK driver i think its called insalled while phone was off. I am running windows 7 and i followed the youtube video instructions (I guess this is where i went wrong) and i read a instuction pdf. Will blackview release a wireless update from os 6 to 7 sometime or will this be the only way? any advice or criticism welcome :lol:
Tue Jul 04, 2017 2:13 am
Download only- flashes the rom cleanly by formatting userdata,system partitions etc.
Firmware upgrade- is a dirty flash, just replaces the system partition
Format all- formats everything, losing your imei and other parts of key information.
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 11
