AeroView
Power button not properly working
Tue Dec 15, 2015 9:31 am
After one week the power button stopped working properly not even after performing factory reset.
The behavior is as follows:
[*]Insert the battery pack, then push the power button does start the phone, although it seems it takes very long to come up.
[*]Once the phone started screen input and programs seems to run properly.
[*]Wait until screen lock timeout or push the power button to put the phone on standby.
[*]From there on, the phone will remain in standby, black screen. Pushing the power button will not awake the phone anymore.
[*]Phone seems to work, it does pair with other Bluetooth devices and plays music if audio jack inserted, but it will not awake the screen input anymore.
[*] Power it down only by removing the battery pack
The re-seller does not answer to my emails....
Is this a hardware issue or software ?
Can this be fixed ?, how ?
Thanks from Belgium.
Re: Power button not properly working
Wed Dec 16, 2015 3:27 am
So sorry to hear your problem .
The Power Button can help you to turn on the phone, right ?
AeroView
Wed Dec 16, 2015 4:40 pm
Hi
Yes, that's correct, the behavior can be seen here on this video:
https://www.dropbox.com/s/y0lz7b3nwytmd ... 7.3gp?dl=0
I can turn on (start) the phone, then I can push it once more to put it into standby mode, but it does not work to take it out from standby.
Any ideas ?
I'm considering to open it (breaking the guaranty seals) to see if I can fix it. What do you think ?
Pitty, I love this phone :(
Thu Dec 17, 2015 9:31 am
Hi
I have seen the video, i need to ask the tech engineer why this happen , any feedback
I will tell you !
Best regards,
Admin
AeroView
Thu Dec 17, 2015 12:57 pm
I've also noticed yesterday an screen re-orientation problem. Regardless of the screen orientation movement and configuration setup, it always remain in "portrait" and never goes into landscape mode.
Also, sometimes, for no apparent reason, it hangs on doing something and delays screen input. The phone is still in "factory reset" mode, thus no new apps just a wifi connection and the google account configured. But that delayed response is hard to measure.
Maybe there's some faulty hardware in there. :(
Could I should request a new "main board" to be shipped to my home address ?
I can change it as per in your YouTube video
https://www.youtube.com/watch?v=I4ZH3SOqAao
(I have all the tools and the technical level to do it)
Thanks
Mon Dec 21, 2015 8:47 am
Thanks
Hi ,
have you ever contact the seller? How do they say to your problem ?
Best regards,
Admin
AeroView
Tue Dec 22, 2015 10:15 am
Yes, of course, before asking difficult questions on this forum I did that.
Try several times over email and chat, but they do not reply to my messages. They let me down once the sale was over but before that happened they told me that the BV5000 was covered by 1 year warranty.
The re-seller is an AliExpress re-seller, Seven Eleven:
http://www.aliexpress.com/store/102802
There's also the issue that sending to phone back to China might have significant shipping costs.
Which company should be responsible for the device warranty ?
Do I understand that I'm running out of options here ?
Wed Dec 23, 2015 7:42 am
In fact , you really need to contact the seller first, or could you give me an web link of the re-seller ?
Best regards,
Admin
AeroView
Wed Dec 23, 2015 3:14 pm
Of course, and I did send them messages multiple times and continue to send them messages ... latest yesterday but got no reply to a single one of them ....
In my previous post you have the re-seller web-link: The re-seller is an AliExpress re-seller called "Seven Eleven". Their shop is here:
Thu Dec 24, 2015 8:47 am
Hi ,
we will help you to contact the re-seller , but how can the re-seller to contact you , do you have the email ?
Best regards,
Admin
