anderson23
Re: Firmware P2 lite: Exchanged microphones
Fri Aug 11, 2017 11:45 pm
I bought a blackview p2 lite and the device came with problems in the software of the microphone, the device is muted, the person on the other side does not hear what is spoken and messages of whatszap are also muted.
After restarting the device the problem is solved for a while but soon it happens again.
I have to restart the device at least twice a day. I wonder if you are fixing this issue and posting an update to fix the problem.
Tue Aug 15, 2017 10:01 am
I will report this. please try this:
update to the latest Firmware and perform a factory reset in recovery* after that.
*wipe data/factory reset in recovery (this will delete your data/settings):
Tue Aug 22, 2017 6:37 am
If the factory reset doesn't work, you can try to flash your phone with the below rom to fix your problem.
P2lite_blackview_201706221607
https://mega.nz/#!RCowgDYQ!eq0B_nHryvKn ... BwHjZExPMY
